Can a dead battery cause damage?
Old Oct 27, 2003 | 01:24 PM
marcrobson's Avatar
Default Can a dead battery cause damage?
I have a Magnum 500 (2000). Someone recently left the key and lights on and left the starter switch set to Run. When I went to use the bike I discovered a dead battery and noticed all the switches on.
I have charged the battery and have tried other batteries. None work - it won't start, run the headlights or even light up the the 'dashboard' lights.
I cleaned the contacts and leads with a stiff wire brush while I had the battery removed for charging and also topped off the battery with distilled water.
If it was turning over weakly, I wouldthink that it was time to replace the battery. But I am getting nothing, as if maybe there is a blown fuse or something else blocking the current.
I think there is a fuse in that 'bubble pouch' right near the battery but dont want to cut it open without knowing for sure and also without knowing how I would go about re-sealing this pouch - I suspect it is airtight to keep water off of whatever connections are made inside it.
Thanks in advance for any/all help,
Marc
Old Oct 27, 2003 | 02:11 PM
WISTECH's Avatar
Do you have the battery terminals on the wrong lugs?
Old Oct 27, 2003 | 02:44 PM
marcrobson's Avatar
No, they are on correct, red is on + ... the bike did have a few mods (snorkle, bypass of the fan thermostat, etc) when I bought it but no one would have a reason to swap the battery leads would they?
Old Oct 27, 2003 | 10:06 PM
Lukester's Avatar
I think the pouch is a fusible link - not sure? Maybe someone else can help with this one?
slowgsxr97
Mar 18, 2022 03:40 AM
Hunter100us
Oct 7, 2015 11:46 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
ScopeZ_
Jul 28, 2015 01:44 AM
