problem with Rawhides
Old Dec 13, 2003 | 12:58 AM
Traildog's Avatar
Default problem with Rawhides
If I were you I'd be wanting to know where the leak is. Blow the tire up to 10 psi and use soapy water all over the tire or submerge it in water. Once you know were the leak is you should be able to fix it.
Old Dec 13, 2003 | 01:18 AM
BigBadScrambler's Avatar
Originally posted by: brainpause
Did you put the slime in, and then drive IMMEDIATELY to spread it out throughout the tire? I put it in mine, and don't have the vibration.
Larry
Sure did. But then it had to sit about 3 weeks before I could go riding again. I dont get the vibration until I am at apeeds in excess of 40mph
Old Dec 13, 2003 | 01:18 PM
keefer's Avatar
I sprayed soapy water on the bead and it's leaking in a couple different spots so I know for sure it's the bead. And this is after 2 times to 2 different tire shops(that work w/ ATV tires) and having them apply bead sealer. A friend recommended using the Slime-type product from Highlifter.com. Slime supposedly isn't for bead leaks(although I know people have used it for that), but the Highlifter stuff is. We'll see how it works.
Old Dec 14, 2003 | 01:06 AM
NGK425's Avatar
slime is great stuff. I "slimed" all 4 tires on my machine when 1 tire started losing air regularly about 18 months ago. I have not added air to these tires once in the last 18 months and have put them thru 700 very tough miles since then. BigBadScrambler is right though, higher speeds will cause a vibration. I also notice the vibration just over 40 mph. Most of my miles are below 40 mph so it is no big deal to me. The "Slime" container says it is only to be used in tires that will not exceed 45 mph.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
