Brighter Headlights
Old Dec 21, 2003 | 11:42 AM
SuperX's Avatar
Default Brighter Headlights
what's the highest in watts you can go up in these bulbs for a '00 Trailblaer, mine went out so Im needing a new bulb, and I want one of the highest, dont need to blind anybody because noone should be out roaming the woods at night [img]i/expressions/face-icon-small-tongue.gif[/img] what you do you guys think?
-Brandon
Old Dec 21, 2003 | 12:01 PM
scrambler420's Avatar
55 watt bulbs should do the trick,i wouldnt go any higher than 80 or so..
Old Dec 21, 2003 | 12:23 PM
Traildog's Avatar
I installed a 100W bulb out of a P sled and that works great. Check your alternator output which should be on the spec sheet make sure you have enough. I would suck if your batter died on the trail.
Old Dec 21, 2003 | 09:54 PM
SuperX's Avatar
do you know which model # or what to get...?
Old Dec 21, 2003 | 10:41 PM
Traildog's Avatar
Go to the dealership and ask for a sled bulb.
Old Dec 22, 2003 | 12:53 AM
i know the bulbs in my polaris sled wont fit into my scrambler so im assuming the sportsman bulbs are differnt than the scrambler?
Old Dec 22, 2003 | 01:17 AM
Traildog's Avatar
The Sportsman has different light than the Scram. To be on the safe side take your existing bulb with you to the P dealer and ask for the 100W version out of a sled.
Old Dec 22, 2003 | 02:27 AM
modquad's Avatar
If I'm not mistaken, the 250 has a 150 watt stator, I wouldn't be putting too much more than what's already on there w/o calling Ricky Stator and upgrading to a 250 watt unit.
Old Dec 22, 2003 | 10:35 PM
Traildog's Avatar
I believe (this is from memory) the engine consumes 40W of power to run, the rear light (if it has one) takes another 6W, the headlight another 100W. You are dangerously close to running out of power only 4W to spare. If you have electric hand/thumb warmers etc. etc. you're over the top.
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 16, 2015 01:33 PM
