Polaris Saddle Bags (Tank Bag)
Same as brainpause here I dont use velcro on the and they dont flop too bad.A word of caution to older Magnum riders these bags will cover the clutch vent and mess things up.I cant use them on my Magnum but work great on the same yr of Sportsman.
The "Tank Top Bag' from polaris looks pretty good! Can you fit a lot of gear in it? Is it easy to remove when refueling or do you even have to remove it? What I am looking fro is somwhere to put my binoculars and my camera as well as maybe a few other things but those are the most important.
Ya camoman, The "ttb" has easy enough room for a pair of 10x50 binos and a 35 mm cam, plus more, mabe sunglass in a case and a cell phone and small wallet. When you gas up you just unscrew the cap like normal. There is a small strap that goes around the filler neck on the tank then 2 straps, 1 on each side hook under the side panles below the gas tank. Its kinda hard to explaine untill you see it but its nice. I'll see if I can find a link you can click on and I'll send it to you. http://www.atvpartsstore.com/atv_log...op%20bags.html
There you go, that was easy enough lol, check out this link.
