good dieting idea for the trail blazer
Old Jan 4, 2004 | 07:17 PM
  #21
BoonDockBasher's Avatar
Default good dieting idea for the trail blazer
sleeper hes saying your TB is like a "sport compact"...however it is not a small imported POS...so its not a "sport compact"
Old Jan 4, 2004 | 07:22 PM
  #22
tbsleeper's Avatar
haha my quad aint nutin close to a sport compact lol thanks for explainin
Old Jan 4, 2004 | 10:54 PM
  #23
EAB's Avatar
EAB
Those nerfs on birddogs bike look good, polished up with the heel guard and all. Those would fit on a scrambler right? What do you think the weight savings would be in the changeover from the standard floorboards to these nerfs?
Old Jan 5, 2004 | 12:31 AM
  #24
ajo771's Avatar
Any nerfs will required some simple fab work. The old boards get cut off, I heard that saves like 20lbs.
Old Jan 18, 2004 | 11:54 PM
  #25
96trailblazer250's Avatar
hey guys my rear brake doesnt work and i was thinkin about takin the whole brake system off for some weight savings but do you guys think it would be worth it? also, how much weight do you think it would save me?
thanks
Old Jan 19, 2004 | 12:02 AM
  #26
BT250racer's Avatar
im going to guess if you do that your going to loss about 7 pounds well if you use the back brakes alot its not worth it but if you just use the handler bar brake then i would b/c when u use that its 70% front brake and 30% back.
1999 250 trail blazer
k&n filter DG exhaust
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
and i made a stronger back caliper holder
so it doest brake when ya hit big rocks
Old Jan 19, 2004 | 05:25 PM
  #27
talonhawk's Avatar
I took mine off and it was 10 lbs. I don't miss it at all!
Old Jan 19, 2004 | 05:36 PM
  #28
tbsleeper's Avatar
i may as well mine backs dont work at all and my handlebar ones are just front though because i wore out the back ones doin burnouts when it was stock.
Old Jan 19, 2004 | 10:32 PM
  #29
yeah same here when we got our tb the back brakes didnt work at all so im used to not having any
jace
Sep 10, 2020 08:30 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
97TrailBlazer
Dec 6, 1999 10:33 PM
