Hard to shift Sportsman 400
Old Feb 2, 2004 | 04:24 PM
TreeDoc's Avatar
Default Hard to shift Sportsman 400
Breeze just gave me this idea....
I'm still under 10 hours on my SP400. I am noticing that it can be quite hard at times to shift the machine...mostly from Park to whatever but sometimes even between H & L or R. Is this a linkage adjustment issue or an internal issue? I saw somewhere on here that somebody just plain busted their shifter and I don't want to be doing that! Any thoughts?
Old Feb 2, 2004 | 04:33 PM
50021's Avatar
You might have shot your oil during the break in period and it is time to change it, The engine oil also effects your shifting, also check your linkage to it sounds like this is more a linkage problem. I have never heard of this happening before on a sportsman,
Old Feb 2, 2004 | 05:56 PM
Polaris500HO4x4's Avatar
As you said its still under 10 hours. it could just be new and not completly broken in, mine was a little hard to shift when it was new. now i have lots of miles and its alot better. also if you push in your foot brake when shifting it helps somewhat.
Old Feb 2, 2004 | 06:04 PM
TreeDoc's Avatar
Out of habit, I always seem to have my foot on the brake pedal regardless of the gear I'm shifting from or to. It generally just takes a "pop" to get it out of Park. If you try and be real gentle with it it seems like it would NEVER come out of that gear
Old Feb 3, 2004 | 11:58 AM
ktmguy70's Avatar
Also could be that your belt is out of alignment. You may want to take of your cover, and watch it while its idling in neautral and make sure your belt isn't spinning. if it is, then make sure your idle is in the 900-1050 range. If its still spinning, then you may need to shim the secondary out some. Of course if its not, then it may just be a simple linkage adjustment.
Old Feb 3, 2004 | 06:38 PM
ftwflh's Avatar
Slow the idle down a hair and if that dont help check the adjustment.If it is in adjustment your shifter could be out of oil .
Jmuddin284
Jan 19, 2026 07:16 AM
GregM
Mar 6, 2018 06:53 AM
ghost civic
Jul 19, 2015 10:13 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
