how can i pull the counterbalence???
Old Feb 6, 2004 | 06:48 PM
Jayblazer's Avatar
Default how can i pull the counterbalence???
im sure someone on here has a way to pull the counterbalance without the polaris tool any suggestions
would be appreciated...
Old Feb 7, 2004 | 10:26 AM
Jayblazer's Avatar
ttt come on guys i could really use some help on this one..
Old Feb 7, 2004 | 10:37 AM
modquad's Avatar
I know the specialty tool works great. I do think some have used gear type pullers, be patient, maybe someone will chime in.
Old Feb 7, 2004 | 10:44 AM
Jayblazer's Avatar
is this something that i should be doing?? is there alot of specialty tools involved i have the manual and i dont see anymore but im not sure how once i get it out and get it repaired im going to get it back in??
Old Feb 7, 2004 | 12:26 PM
CED's Avatar
CED
I have never done it with the motor in the frame.With motor ouof the frame and apart you can heat the cases exactly where the manual say's and it will come out.Or you can tap it out from the backside if you have the cases apart.I don't think this will help much,good luck.
Old Feb 7, 2004 | 01:56 PM
NascarFan's Avatar
I did my 400 and pulled it out with a slide-hammper puller like they use for pulling axles out. When I got the gear/shaft out the inner bearing was still in the case. I took the same tool with a adaptor that commes with the puller that has a small lip on it. Stick it inside and hook it behind the bearing and then stick a large screwdriver in with the puller to hold it lipped in on the bearing and tap it out."Thats my story, and I'm a sticking with it." Good luck. Charles
Old Feb 8, 2004 | 03:12 PM
Jayblazer's Avatar
how do i get to the oil injector to remove it???
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
black798
Sep 9, 2015 07:42 AM
awer1968
Sep 8, 2015 11:02 AM
