TB 400 vs ???
Old Feb 10, 2004 | 02:29 PM
TB400RIDER's Avatar
Default TB 400 vs ???
I'm in the process of putting an HPD PIPE, SILENCER, CLUTCH KIT, and K &N on my 2003 TB. What is the fastest quad I'll be able to drag? YFZ 450 ???
Old Feb 10, 2004 | 02:34 PM
Randalscandal's Avatar
ahh i don't think that u will b able to take a yfz.......but what kind of clutch did u get and where please answer!!!
Old Feb 10, 2004 | 02:44 PM
TB400RIDER's Avatar
I got the HPD Aggressive clutch kit.
Old Feb 10, 2004 | 02:45 PM
POLARISFREAK's Avatar
You can probably give a warrior and a 400ex a run. The pipe and clutch kit help alot, but it'll take some porting for the list of things you can outrun to really grow!
Old Feb 10, 2004 | 04:45 PM
Elbongo's Avatar
You will smoke the warrior and easily outrun the 400ex. A stock 400ex is just a little bit faster than a tb400. You should be able to play with stock Z400's. The pipe.clutch kit,air-filter add a lot of power to the tb400. Polarisfreak made a good suggestion about getting your cylinder ported to really kick some booty!
Old Feb 10, 2004 | 08:08 PM
ftwflh's Avatar
DITTTO on the porting but until you are ready get you a set of good reeds.
Old Feb 11, 2004 | 11:56 PM
TB400RIDER's Avatar
How many mods can you do before you should change the stock piston?
Old Feb 12, 2004 | 12:09 AM
duneaholic's Avatar
With what you have I wouldn't do much more. The stock cast pistons tend to break and can cause some major damage. Go with a Weisco piston. They are forged and lots stronger than stock.
