how to install hand warmers
Old Feb 20, 2004 | 09:11 PM
tommyatv's Avatar
Default how to install hand warmers
I would like to install hand warmers on my 04.5 Polaris 600. who makes the nicest kit. how big of deal is it to wire. were do you install the switch. thanks for your advice . I am new to atv.
Old Feb 20, 2004 | 09:26 PM
roscoe69's Avatar
handwarmers are a good investment and easy to install, you can get the electric films that install under your preasent handle grips or buy a set of grips with the hand warmers installed inside them. the handwarmers that are installed will probably be the best choice for durability . the film handwarmers will be the cheapest but will work fine . im not familiar with the polaris quad but there must be lots of places to drill a hole for a switch try to pick a place where it will be protected from water etc, olso it should be positioned where you or branches will not hit it olso. a switch should be wired through the ignition switch to make sure it is not left on causing a dead battery. most quads have a plug in for acessorys that is wired through the switch making it a good choice to get a electric supply. do a search on the subject , use all the forums , there has been a lot posted in the past.
Old Feb 20, 2004 | 09:34 PM
tommyatv's Avatar
thanks roscoe! yes i am going with the new grips with the heating wire in them. I want the switch to look like a factory item. like snowmobiles have. I am new to this web page and learning how to use it. Thanks again.
Old Feb 20, 2004 | 10:18 PM
nccracing's Avatar
Welcome to the site Tommyatv , Enjoy yourself .
franklyme
Oct 21, 2016 07:18 PM
fordfaithful21
Dec 7, 2015 05:52 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
