Pred won't start.
Old Feb 24, 2004 | 07:25 PM
aussiequadrider's Avatar
Default Pred won't start.
Guys I think you can relax about the Wiggles their pretty harmless.
A lot safer than ozzie.
I charged the battery overnight, still nothing, so I suppose I now have to get the battery checked.
Geoff.
Old Feb 24, 2004 | 07:31 PM
fidge1's Avatar
Maybe the battery will not hold a charge--- but it should start with the charger on it
Old Feb 24, 2004 | 07:51 PM
ATVBos's Avatar
well i wouldn't try to srat it with your chager unless you have a bost stage on it, but even then that is really only ment to help it along if your just need a little boost to get a little more cranking rpm. but rather use a piar of booster cables and jump startit from lets say your car of another bttery.
Old Feb 24, 2004 | 07:56 PM
It's okay to jump start quads from cars?
Geoff.
Old Feb 24, 2004 | 08:06 PM
  #15
Bradracer18's Avatar
Yeah I think it is, but I would stick with the battery charger if it were me.
Old Feb 24, 2004 | 08:27 PM
  #16
Hozed's Avatar
ya ive done it before... but i usually try hookin jumper cables from my truck to the battery... it should start but not hold a charge like said above...
Old Feb 24, 2004 | 09:44 PM
  #17
50021's Avatar
your carbureator might be a little dirty from sitting around for four months and it might not want to run, might be a combination of both battery and carb.
my cousins 400ex sat arounnd for 4 months and wouldnt start because the carb was gummed up with fuel and other junk, just a suggestion
Old Feb 24, 2004 | 10:04 PM
  #18
ATVBos's Avatar
Yes it is totaly fine to jump start from you car or truck they run at the exact same voltage 12v to 14v, 14v if the altornator is runing to charge the battery same as a quad. I have done it many times. and if that wasn't true then they whould not put lighter outlets on quads as well !!
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
BYC
Sep 25, 2015 02:10 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
JDawg8309
Sep 12, 2015 02:24 PM
