scrammy tires and wheels
Old Feb 24, 2004 | 09:13 PM
iwannabfast's Avatar
Default scrammy tires and wheels
if i put tires and wheels on my 95 scrambler 400 4x4 do i have to change gears one of my friends said i did
i want to put holeshot's and aluminum wheels
Old Feb 24, 2004 | 09:16 PM
BigBadScrambler's Avatar
No you dont, as long as you keep the 1" difference between the front and back. In fact, you dont want to change gears with the 4wd. It will throw the engagement of the 4wd off
Old Feb 24, 2004 | 09:17 PM
so what size do you recommend
Old Feb 24, 2004 | 09:18 PM
csamayfield55's Avatar
you have to keep the ratio the same for the front to back If you put 20" tiers on the rears you need 22" tires on the front, I think it is 2 inches bigger in the front anyway!
If you don't your 4x4 will not work right
Chris
BBS beat me 2 it!!
I guess it was 1 inch, my bad
Chris
Old Feb 24, 2004 | 09:26 PM
Taller tires= More top end, less acceleration, and more ground clearance
smaller tires= Better acceleration, less top end, and probably better handleing
It all depends on what you want
Old Feb 24, 2004 | 09:53 PM
are holeshots ok in the mudd or do i need to stick with stock type tires and different wheels
Old Feb 24, 2004 | 09:57 PM
That depends on the type of mud. Light mud they will do OK, but any deep or gooey stuff and you are SOL. Mudlites or 489XT's would be better suited for deeper mud than holeshots
velcro7279
Aug 24, 2015 01:15 PM
DFWSRT8
Aug 20, 2015 09:24 AM
Jul 24, 2015 11:57 AM
rcappie4
Jul 18, 2015 07:51 AM
