Clutch Springs and kits???
Old Feb 26, 2004 | 12:12 PM
Bubs's Avatar
Default Clutch Springs and kits???
I was wondering if changing my clutch springs would give me more top end speed,without taking bottom end power away?or would i have to get a kit for my 04 sportsman?Thanks in advance
Old Feb 26, 2004 | 01:03 PM
BigBadScrambler's Avatar
You really arent going to gain any top end speed with a clutch kit. It will however improve your bottom end and acceleration
Old Feb 26, 2004 | 02:56 PM
Russ7R's Avatar
You will not gain any more speed with a clutch kit, exhaust, jet kit....unless you change the gearing. You may get there faster, you may be able to maintain you top speed better with these kits but it will not make your top end faster.
Russ
Old Feb 26, 2004 | 05:41 PM
lovemud's Avatar
Clutching is really an art form, there's a TON of aftermarket parts and kits. Primary weights of diffrent shaped and sizes, springs with an assortment of conpression rates. But, when your sheeves on your primary are closed that's it, thats as high as the grea ratio gets.
Some stock machines are faster than others, and if your concerned your not getting what you should for you model you need to make sure your existing setup is working like it should. Check to make sure your weights move freely, and your sheeves can close/open all the way as well. Also, make sure you don't have a broken spring.
The aftermarket stuff can make a world of diffrence for trailriding. I use a modified heelclicker kit for trail riding. It gives my a TON of low end torque, I don't even bother shifting into low anymore for 99% of the stuff I encounter on the trails.
Old Feb 26, 2004 | 09:31 PM
ftwflh's Avatar
LIKE I HAVE SAID OVER AND OVER "GET A POLARIS WHITE SPRING" IT WILL DO MORE THAN YOU THINK!!!!!!!!!!! FOR A STOCK MACHINE.
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
mitchxc700
Aug 19, 2015 02:41 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
