How fast will a 700 Sportsman Go??
Old 03-06-2004, 01:10 AM
BT250racer's Avatar
Default How fast will a 700 Sportsman Go??
well guys i had a friend that rode one before at top speeds on the rode ( turns ) and he said it was so i was just going with what he said the only time i ran one was only in the woods for liek 20 mins
  #22
Old 03-08-2004, 09:32 AM
Sep1's Avatar
DG Polaris, Yep remove the nut gain a few MPH. This will let the clutch shift all the way out. Don't think for a minute that I discovered this, I didn't. The guy from Dalton Inds. told me this. They do extensive testing on the kits and found this to be true. For an example to a serch on 600/700 sp. There was a guy stating that the motor was reving but would not go over 45-50. As it turns out the nut loosed up, thus limiting the shift-out.
  #23
Old 03-08-2004, 09:40 AM
Bubs's Avatar
do the 500s have this plastic nut on the primary too?
  #24
Old 03-08-2004, 09:48 AM
SPORTY700's Avatar
All Polaris with EBS have the limiter nut, just be warned that removing the nut allows the belt to be forced all the way to the bottom of the secondary clutch which will cause belt failure.
  #25
Old 03-09-2004, 01:46 AM
fishslab's Avatar
Originally posted by: DGpolaris2346
Wait so if i remove that little white nylon thing off of that long bolt that you take out when removing the primary spring i can gain 1-2mph?
No, not the one on the bolt that holds the primary to the crank. It's part number 8 on this link I posted. It's only on the EBS models.
  #26
Old 03-09-2004, 08:52 AM
Sep1's Avatar
Fish,
Thanks for clarifying that. That could have resulted in a few nasty responses for us.
BTW, I have had my nut of since Aug, when I installed the new Dalton clutch spring, and I have not seen any extra wear on the belt. I haven't been to kind on it at all this winter pulling 1500lbs trailers as well as WOT doughnuts on the ice. Seems like it has no effect but positive.
  #27
Old 03-09-2004, 09:29 AM
DGpolaris2346's Avatar
Mine is non ebs can i still do this?
  #28
Old 03-09-2004, 09:36 AM
Sep1's Avatar
DG,
I don't think so, just because you probably do not have the white nut on the primary. I know my 98 Scrambler 500 didn't have one. Your best bet is just to put on a new clutch kit with a new spings, weights and helix.
  #29
Old 03-09-2004, 09:40 AM
ok I'm glad i asked that before i went removing things. Thanks
Jmuddin284
06-28-2017 04:59 PM
mtdewmn
01-19-2017 12:13 PM
RickyMac
03-05-2016 07:27 AM
house1
08-09-2015 10:49 PM
dougn85
08-05-2015 07:20 AM
Quick Reply: How fast will a 700 Sportsman Go??
