lights
Old Mar 11, 2004 | 08:24 AM
  #21
NCSurveyor's Avatar
Default lights
It's a '99 Sportsman 335. The breaker is in a little black bag beside the battery. But how do you trip it?
Old Mar 11, 2004 | 10:32 AM
  #22
TreeDoc's Avatar
Default lights
Have you tried disconnecting both the leads from the battery?
Old Mar 14, 2004 | 08:59 PM
  #23
Trailblazinrider's Avatar
Default lights
Last question. I know very little about the electrical systems, and i need to know if the wiring part was easy. I know that everyone said that the installation was easy, but i am kinda slow, lol. But really, how do the lights connect to the quad. Do they just plug in somewhere, or do i have to sodder them to something? Thanks for all the help !
Old Mar 14, 2004 | 09:48 PM
  #24
TreeDoc's Avatar
Default lights
Tbr, I wired my lights directly to the battery. A red wire goes from the battery (+) to the head light pod where I have mounted a weatherproof toggle switch. It then goes forward and splits with one going to each light (+). The two black grounds (-) coming from the lights go to ground on the frame. I spliced the grounds together and connected them to an existing ground/frame connection. That's it! It's different and a bit more complicated if you splice into the electrical system but I just feel more comfortable now without involving the electrical system, I had an overload issue due to the additional lights and it kept tripping the breaker.
Old Mar 14, 2004 | 10:41 PM
  #25
mudmaster250's Avatar
Default lights
i stripped off the end of my pos wire and put it in the holder and hooked it up. then i did the same with the neg. i ran the positive to the switch and the ran it out of the switch into the splitter and ran it to the wires. i split the neg and hooked to to the lights. i sodered my wires just to be safe but its not neccesary. the rest of my time was spent wiring. scott
Old Mar 15, 2004 | 07:21 PM
  #26
Default lights
thank you guys so much. I will order the lights tonight. If I have any problems i'll let you know.
Old Mar 19, 2004 | 09:48 PM
  #27
Default lights
Just got em, love em. Ya, you were right, they do make a huge difference, and the mounting was easy. I took off all the plastic and it went right together. Now all i got to do is position them. Thanks sooooooooooooo much guys!!!!
-nick
Old Mar 20, 2004 | 01:11 PM
  #28
TreeDoc's Avatar
Default lights
Hey Tbr,
What lights did you end up with and where did you get them?
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
