starter replacement on a tb
Old Mar 22, 2004 | 08:37 PM
paulnkerr's Avatar
Default starter replacement on a tb
How do you do this what has to come off and how hard is it???[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 22, 2004 | 08:47 PM
Hozed's Avatar
i dont think it will be that hard... the starter on my pred has 2 bolts connecting it to the engine... undo those and its slides right out...
and by slides i mean its kinda a pain in the *** but a little convincing and wiggling and it shouldnt be a problem.
o ya... and there are a few grounds that go to and from it...
Old Mar 22, 2004 | 10:08 PM
quadwrench's Avatar
A service manual for this quad would be of a great help to you on this project.
The skid plate has to come off, then there are (2) 10mm bolts that attach the starter rear support bracket to the engine (one is a royal pain to remove, but can be done with some patience), and the battery supply wire can be removed - then the rope starter assembly housing has to come off (exposing the flywheel), one of the housing bolts is long and is (1) of the (3) bolts that holds the starter in the front. Once the housing is off, there are (2) more 10mm bolts inside holding the starter in. The starter and starter drive will now slip out the backside.
Installation is reverse of removal.
Old Mar 22, 2004 | 10:44 PM
Hozed's Avatar
wow... alot harder than the pred one...
Old Mar 22, 2004 | 11:03 PM
JEFF10049's Avatar
Hope mine don't go anytime soon thats way too much work! LOL....
Jeff
Old Mar 23, 2004 | 12:39 AM
03predly's Avatar
It is a royal pain in the *** to do starter work on the pred. You have to have a flywheel puller once you get the stator cover off, or you aren't going anywhere! After that, it's not so bad.
Old Mar 23, 2004 | 06:47 PM
paulnkerr's Avatar
so i guess the best way to do this is to stand it up on end?????
Old Mar 23, 2004 | 11:33 PM
quadwrench's Avatar
The easiest way is to stand it on end........ although, sometimes I prefer to "lay down" on the job [img]i/expressions/face-icon-small-happy.gif[/img]
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
mudpig79
Jul 13, 2015 03:31 PM
