taking off the starter
Old Mar 28, 2004 | 09:55 PM
BT250racer's Avatar
Default taking off the starter
im going to take off the starter to see if i can fix it how hard is it to take off and what other stuff do i need to take off to get it off?
PERFOMANCE
.25 over head, (getting a clutch spring)
K&N filter, DG exhaust ( for now)
12t 36t sprokets,
back--titan 489 xts front--maxxis razors,
shade perfomance trans, D.I.D chain,
armor tech belt, newer model tie rod ends
PROTECTION
skid plate, bash gaurd,
stronger back caliper holder
LOOKS
scott grips, neon shifter, proburner lights,
cut fenders, removed floor boards made aluminum
dimond plate ones, painted bumper,handler bars,rims
Old Mar 29, 2004 | 12:15 AM
Stainless's Avatar
I took the starter off a 95 trail boss today that I bought last weekend. I had to take the side case cover off and remove two bolts from the starter. I then had to get underneath the fourwheeler and remove the bolts that mount to the back of the starter. That was the hard part. The top bolt was in a real tight spot, I had to cut a 10mm wrench in half to make it fit in there to get the bolt off. Hopefully I'll be able to get the local starter guy to add some brushes to it and then I get to have fun putting it back up in there. All the work will be worth it to me to just push the starter button :-).
ghost civic
Jan 15, 2020 07:43 AM
txpedsrt1
Feb 3, 2017 08:07 PM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
