sportsman 500 springs
The SP700 springs will fit. I've got Ranger springs in the front of my '03 500SP. So far, I really like them. Definitely a fair bit stiffer than stock, so they're a little rougher riding, but not uncomfortable. My machine doesn't bottom out anymore and handles much better. It was worth sacrificing a tiny bit of ride quality, IMHO.
here's some info I found when looking for front springs for my ATP
Polaris Atv springs
Spring colors, last 3 digits on part number 067=black, 385=silver, 293=red, 195=???
Stock sportsman 500/ATP springs 7041375-067 / 7041375-035 64-113 LB/in progressive
Sportsman 500/ATP HD replacement springs 7041450-067 101 LB/in non progressive
Scrambler 500 HD replacement springs 7041647-067 80-120 LB/in progressive
Sportsman 700 stock springs 7042054-067 70-120 LB/in progressive
2002 ranger front springs 7041696-195 140-190 LB/in progressive
2003 ranger front springs 7041985-067 120-150 LB/in progressive
Sportman 500 rear HD replacement springs 140 LB/in non progressive
I went with the Scrambler 500 springs (80-120 progressive) I love em ......I have the brushguard, warn2.5i winch, and the glacier v-plow up front
when I first got the quad stock with no acessories installed yet it would bottom out when going about 30mph down a rough trail, now I can run down the same trail with the plow and ecerything on with no bottoming and the ride is still good
handling is better too ....... I was gonna go with ranger springs, but after I found out the spring rates I felt they may be a bit rough riding
Polaris Atv springs
I believe the -195 colour code is green. That's what colour the Ranger springs are in my Sportsman. So far, I'm happy with these springs and after only four rides, they've definitely softened up a little. They also lifted the front enough (approx. 2") so that my quad sits level now. Looks much better.
Polaris Atv springs
Polaris Atv springs
Where did you order them from and what did they go for? and does anyone know what the stock rating are for the scamblers front springs
Scrambler 500 Standard 75/100 lb/in==> 7041648-067
I ordered mine from my polaris dealer but you cvan get em here
http://www.bigbuckrack.com/polaris_springs.htm
