98 polaris 400 sport
#21
Originally posted by: rescuediver
There is alot of good information here to do when looking for a used quad.
Dadsworry, if your concerned about the top end, have a mechanic check it out, he'll give you a hands on opinion on what the quad may or may not need. I wouldn't do it just because someone on the forum says to because his mechanic is the best. Unless you negotiate the price down to cover it. Lt. Dan
#22
Report this to a Moderator
Reply Quote Top Bottom Edit
bisho12
south hadley, Massachusetts
Sat April 03, 2004 7:02 AM
Quote
Originally posted by: JEFF10049
Also I think the 400 sport engine has a counter balance like the other 400's. And I have read on hear that when buying one you should check the counter balance oil for water/coolant. Something about a water pump seal that can leak into there.
Hopefully someone with more knowlage on this will chime in. Don't want to scare you away from it or anything sounds like a great quad and fair price. Just thought of checking that counter balancer oil
Jeff
Yes you need to check the oil for the counter balancer. I just replaced my seals and bearing. It wasnt that hard but becareful of the spanner nut on crank shaft. I had to replace mine along with the seal behind it because i damaged it. I love the 400. Has plenty of power stock for me. I mainly trail ride so I dont need to go 90 mph threw the woods. Check my pics and you can see the case apart.
Bob
1999 polaris sport 400
oil injector block off kit hot seat
MSR "Bark Busters"
New Grips too
everything else stock for now
bisho12
Sat April 03, 2004 7:04 AM
Mine is a 99 and I paid $2,000 for it. It was in good condition runs great and also check to see if the oil injector is working properly. i had a cable broken on mine and didnt know about it until i took it off and put on a hotseat block off kit. It runs better on pre-mix and I know the oil is in the engine no matter what.
Bob
MSR "Bark Busters"
New Grips too
Purepolaris04
Youngstown, Ohio
Sat April 03, 2004 7:39 AM
I got mine for 2700
POLARIS 400 SPORT 1998 2 STROKE DYNO PORT PIPE WITH DG SILENCER AND K&N FILTER AND HANDLEBAR GUARDS. EPI CLUTCH KIT
rescuediver
Central California, California
Supporting Member
Sat April 03, 2004 11:47 PM
1988 Mojave ,K&N Stage 2 Jet kit, Supertrapp. DG nerf bars, PIAA lights,WORKS shock w/ reservoir
1994 Polaris 400L Sport (wife's)
1986 Honda Fourtrax 70
2003 Suzuki 160 QuadRunner
2001 F250 4X4 CrewCab power chip,5" exhaust, 2" lift
RAJ
West Union, Ohio
Supporting Member
Sun April 04, 2004 10:09 AM
The guy I got mine off of....wanted $2,200 it only had 50 hours on it....and it was a 4x4...and in very good shape. Me and the wife went and looked at it. I wanted it bad. I asked him what the bottom dollar was and he said $1900. So I took my buddy over to look at it....he's got a 2003 400. I went to the atm and got the money out. We went over there and flashed $1800 in his face....He took it..and threw in a o'neal helmet. So we loaded it up .
So if the guy wants the money bad he will take less for it. It wont hurt to try. If you can get it for less...then you will have some extra money for mods. I love mine and they are alot of fun.
99 Scrambler 400 4x4 FMF Gold Series Gnarly Pipe, Turbine Core II Silencer, K&N Air Filter with Outerware, Mod. Air Box, V-Force Reeds, Reed spacer, Wiseco piston, RcR porting, RcR head work, clutch kit, 909 Gel Grips.
NOTHING LIKE SMELLING TWO STROKE IN THE MORNING!!!!!!
bisho12
Quote
Jeff
Bob
MSR "Bark Busters"
New Grips too
bisho12
Bob
MSR "Bark Busters"
New Grips too
Purepolaris04
Youngstown, Ohio
I got mine for 2700
rescuediver
Supporting Member
RAJ
West Union, Ohio
Supporting Member
John Boy
Jul 13, 2015 11:16 AM
