reverse woes on scrammy
Old Apr 8, 2004 | 08:41 PM
Powerstrokinsportsman's Avatar
Default reverse woes on scrammy
When I try to put the scrammy into reverse it just doesn't engage. One out of maybe 6 or so tries engages correctly and the other times the tranny just clanks like it went into gear but didn't. I have adjusted the shifter linkage both ways trying to see if it helps, but neither way makes a difference. Anybody have any suggestions?
Old Apr 8, 2004 | 09:10 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
is your idle set too high?
Is you linkage damaged?
do a search on linkage in the polaris forum,,,,it has been covered before
Old Apr 8, 2004 | 10:32 PM
ftwflh's Avatar
If your idle is ok and the shifter is adjusted right about the only other thing to check before tearing into the tranny is the bell crank arms on the shifter at the tranny.these have a tendancy to get worn and have slop in them.Check this before anything else.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
salixair
Nov 3, 2015 08:25 AM
r1pilot83
Sep 27, 2015 07:38 PM
poutlaw525
Sep 9, 2015 03:19 AM
