cuts out at idle
Old May 17, 2004 | 06:36 PM
trailblazer250p's Avatar
Default cuts out at idle
My 2002 TB250 cuts out at idle what wrong?
Old May 17, 2004 | 07:27 PM
DGScrambler400's Avatar
does it work otherwise, i.e. riding? Your idle screw may be too low if it works fine when the RPMs are higher
Old May 17, 2004 | 07:31 PM
BigNig's Avatar
check idle screw gas is on reserve? [img]i/expressions/face-icon-small-confused.gif[/img] mine does it too some times, just play with idle screw on make sure gas is on ON position [img]i/expressions/face-icon-small-wink.gif[/img]
Old May 17, 2004 | 07:47 PM
csamayfield55's Avatar
sounds like the throttle cable is a little loose. you may need to tighten it up some with the adjuster near the handlebars. Polaris bikes have a safety switch in the throttle that keeps you from having a runnaway from a stuck throttle
Chris
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Minimod
Sep 10, 2015 08:03 AM
Elkaholic
Sep 6, 2015 02:44 PM
