can someone tell me the steps to.....
If you have access to a 1/2" impact, you may need to "pack" the clutch w/ grease, then thread in your puller. Once you have it started in a few threads (put on some safety glasses, and some old clothes) then hit it full tilt with the impact. It "hydraulics" the clutch off. Of course, it also "hydraulics" grease around....but hey, your clutch will come off.
I've heard of Richmond before, where about's are you?
Continue to thread the puller into the drive clutch until you can not turn it any more. After that give it a couple taps with a hammer and continue to turn the puller into the drive clutch. Continue to repeat this until the drive clutch pops off of its shaft. Turn the puller as hard as you can until the clutch pops off, dont worry you wont wreck anything but turning really hard, it is on a tapered shaft and takes a lot of pressure to get the clutch off of there. I did not use anything but regular tools to get this off of there, though an impact gun would have been nice. Make sure you torque everything back to spec when you re assemble it. any further questions let us know
09-22-2015 10:35 AM
