Sportsman Carb questions........
Does anyone know the stock jetting on my 335? Also is rejettig a Polaris the same as my 400EX?? Meaning is the jet on the bottom..is it hard to get to?....also what brand of carb..is it a Mikuni or Keihn (sp?)..
One more...do you jet up or down the higher the elevation??...I regularly ride at 11,000-12,000 ft.
Thanks, Drew
Thanks, Drew
It's a Mukni, I know my SP 500 came stock with a 142.5 main, You will want to go down in numbers for higher elevation. Remember, higher ground = less air so you need less fuel for the mixture. Also most stock bikes come fat so don't be afraid to drop one extra number on your main, 4 stroks are pretty forgiving.
bzdok1234
30
02-23-2016 01:55 PM
