any suggestions
Old Jul 31, 2004 | 08:03 PM
ElDuderino's Avatar
Default any suggestions
I have a 92 trail boss 250, nothing special. Anyways, its been sitting for almost 2 years and I was trying to get it running again today. Compression is good, spark is good, replaced the fuel filter cleaned out the tank and put fresh fuel in it. Can not get the thing running though, it just cranks and cranks but wont run. When i put starter spray in it, it will fire right up run for a sec or two and shut off like it isnt getting fuel still. Any suggestions on what to try next to get the darn thing running at least. thanks
Old Jul 31, 2004 | 08:12 PM
fishslab's Avatar
Have you taken the carb off and cleaned it? If not that looks like your next step. Use compressed air to blow through the little passages and lot of carb cleaner.
Old Jul 31, 2004 | 09:24 PM
tbsleeper's Avatar
sounds like the cylinder wall is crappy
Old Jul 31, 2004 | 09:29 PM
yammaslamma's Avatar
tbsleeper may be right or if u have a fuel filter check that out.
Old Jul 31, 2004 | 09:31 PM
Jayblazer's Avatar
its a dumb question but i have a tendency to overlook the obvious. Is the fuel on?
Old Jul 31, 2004 | 09:32 PM
lol jayblazer no worries that has happen way to many times here......
Old Aug 1, 2004 | 01:01 AM
midwest's Avatar
I would be 99.9% sure that the carb just needs cleaned. Its actually a pretty easy job to do, some people are intimidated though. take carb off the bike--take off the float bowl and everything is right there. Take a can of carb cleaner and spray enough into a bowl to submerge all the parts into it and let it set overnight. that will ensure that it will clean all the buildup out of the small passages. then take each part and blow carb cleaner through it and then compressed air through it. Keep all parts organized and clean. reassemble the carb and put it back on the bike. Once fuel hits the carb and can almost guarantee that it will run like a top!!!!!! and make sure you put a FUEL FILTER on, otherwise- all your work will be wasted!!!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
badgerboy1
Sep 26, 2017 06:11 PM
Gwolf228
Feb 18, 2017 01:36 AM
Sw00p
Sep 24, 2015 02:50 PM
toonces
Sep 5, 2015 01:14 PM
