Front fender fix on pred.....???
Old Aug 1, 2004 | 10:05 AM
Bradracer18's Avatar
Default Front fender fix on pred.....???
Hi guys......well it finally happened to me.....damn.....I am pissed at the polaris engineers. I realize the front fenders come off very easily, but those gas tank mounts are junk. Anyways, how do you guys suggest fixing the tank mount? The plastic is broken off smooth, and I'll have to buy a new mount, because I lost it. What have you guys done?? Thanks a lot guys.
Old Aug 1, 2004 | 11:15 AM
1Toby1's Avatar
I also was unhappy with the way the plastics mounted to the tank. What I did was to remove the c-clip on the plastics and the bolt and washer out of the tank. I carefully measured and drilled a hole through the plastic on both sides lining up with the bolt holes in the tank.
I went to Ace hardware and got longer bolts, nylon washers, and a metal trim washer to go over that. Then I bolted the plasics directly to the tank. Much better!! No more rattling or vibrations from the front plastics and it looks like it came that way [img]i/expressions/face-icon-small-smile.gif[/img]
My digital camera is broken or I would post up some pics
Hope this helps... Toby
Old Aug 1, 2004 | 11:22 AM
Thanks Toby......that was kinda what I was leaning towards......I guess I'll go try it, and hopefully it comes out all right. I guess precision and measure and measure again are going to come into play here. Thanks again. Brad
Old Aug 1, 2004 | 11:32 AM
1Toby1's Avatar
Actually what I did to make sure the hole was exactly in the right place was to install the stock bolts into the tank and use a paint pen to color he tops of the bolts. Then I put the plastics on, lined them up and pushed it against the mounting bolt leaving a mark on the inside of the plastics. Perfect place to drill [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 1, 2004 | 07:24 PM
Sounds good, I'll give it a try......Thanks again.
Old Aug 1, 2004 | 11:34 PM
No one else has had this problem??? If you did, what did you do to fix it??
Old Aug 2, 2004 | 12:37 AM
trailrider500's Avatar
Brad,
It happened to me too.
I after looking at it for a while the only good idea i could come up with was what 1toby1 said.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
