basic info on the pred plz
Old Aug 1, 2004 | 02:36 PM
QuadAddiction's Avatar
Default basic info on the pred plz
Whats the pred hp? and what its top speed
please refer to the 05 new models with the change in the gear ratior...
and any idea if stock for stock it accelerate like my ds ??
Old Aug 1, 2004 | 04:22 PM
trailrider500's Avatar
hmm
hp 42 stock, they say the new 05s make 50?
Top speed 73-75mph not change on the 05s
The 05s(TLD) will accelerate faster then the 04s due to the close ratio trannny
It should out accelerate the DS stock for stock but the DS has a higher top speed.
Old Aug 1, 2004 | 05:51 PM
closer ratio does make it accelerate faster but does it effect the top end, i mean lower it down?
Old Aug 1, 2004 | 05:53 PM
etwake's Avatar
It will not affect top speed because they only changed gears 1-4 in '05 TLD
Old Aug 1, 2004 | 05:58 PM
BigBadScrambler's Avatar
2nd-4th gear are close ratio. 1st and 5th gear are still the same which will not affect the top speed at all. All close ratio means is that you are able to get the rpms up between shifting the gears, which will help you stay in the powerband more for better acceleration
Old Aug 1, 2004 | 08:35 PM
Ok 10x alot...
I've been wondering if i should replace my ds to 05 TLD Predator...
I'm doing well on my ds, some told me ill do better on the pred cuz im only 170cm and i weigh 125 lbs...
whats your opinion??
Old Aug 1, 2004 | 08:37 PM
The DS is a lot of machine for your size IMO
Old Aug 1, 2004 | 08:48 PM
I guess you kindda right there...
but i like the DS speed and acceleration and it's super comfortable and a reliable machine...
does the pred that way too?
having a rough time choosing between those machines... : \
Old Aug 1, 2004 | 08:52 PM
I would say make a trip to your local Polaris dealer and ask to take an 05 TLD Pred for a spin. I think you would like it
Old Aug 1, 2004 | 08:59 PM
Stuzilla's Avatar
I have a question, is the difference in price between the troy lee edition and the regular pred worth it? I mean, is the TLD worth the extra $$$?
