Close ratio tranny question?
Old Aug 14, 2004 | 08:48 AM
  #21
fishslab's Avatar
Default Close ratio tranny question?
I think the more important thing with the close ratio is that you don't lose as much rpm and hp between shifts. I also think it may reduce shifting by being able to recover better in mis-shifts or wrong gear situiations. Lastly it may be easier to speed shift (or whatever it's called.)
Old Aug 14, 2004 | 08:52 AM
  #22
Hozed's Avatar
BAD IDEA WITH THE PRED!!!!!!!!!!
how do you think all those 03 trannys blew??? lol..
thats how mine went anyway. tryin to shift like all my buddys on their yamahas... well... my polaris couldnt do it.
maybe you can now... but you couldnt then.
Old Aug 14, 2004 | 09:04 AM
  #23
fishslab's Avatar
I think there were basically three versions of the speed shift idea.
1. No clutch, WOT.
2. Clutch, WOT
3. No clutch, closed throttle
The way I followed it #1 was real bad. #2 and 3 Most guys had no problems with, but it was arguable.
Old Aug 14, 2004 | 09:10 AM
  #24
GE4x4's Avatar
So far the only experience I've seen with a close ratio is drag racing. I can see why this works, but how well does it work on the trails? Drag racing and trail racing are totally different.
Old Aug 14, 2004 | 09:45 AM
  #25
fishslab's Avatar
If it works the way I think it will, I can see many positives. On open runs you will have good consistent power like a drag. On steep hill climbs the rpms should not drop off as steep between gears. If you miss a shift or are bound up where shifting might be difficult you can get by. Dropping gears to slow down won't over rev you or throw you over the handlebars or pop the front end up.
Old Aug 14, 2004 | 10:02 AM
  #26
powerslider's Avatar
The amount of shifting with the close ratio's won't neccessarily be any more than the regular trans. Depending on the type of trail it may actually be less. With the wide 1-2 gap on the standard you may find on some trails 1st isn't high enough and second is to high so you would be shifting more. With the close ratio trans you could stay in second....
Kyle5050
Dec 13, 2019 04:25 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Haakon
Aug 24, 2015 01:54 PM
ghost civic
Jul 27, 2015 03:15 AM
kdg723
Jul 25, 2015 01:20 PM
