Low Beam + High Beam same time
Old Sep 6, 2004 | 02:10 PM
Tom128's Avatar
Default Low Beam + High Beam same time
Whats the easiest way to get both the low beam + high beam to come on at the same time without to much wiring...
Old Sep 6, 2004 | 04:32 PM
yaaaaaa's Avatar
well its very possible because they do it with all the trucks now, but i just got a kit and it wired right in with no problem.
Old Sep 6, 2004 | 06:15 PM
ATVman00169's Avatar
will on the sportsman. its easy. you can't have high and low.. your Top light has a low and high, the bottom ones only have low.. in side the speedo. "pod" you can hook up the low to the top light. so when low beam is on all 3 light will be on, instead of just the bottom ones.
Old Sep 6, 2004 | 06:36 PM
Bloombastic's Avatar
Hey ATVman: Are you telling me that my pod on my sp700efi has a low beam that just does not get used? I am preparing to do the lights mod this week. The one where you jump the high beam pod with a diode so the two lows stay on also. If I wire it correctly, will I be able to have all three in true low beam?
Bloomer
Old Sep 6, 2004 | 06:58 PM
Tom128's Avatar
Are the kits only sold on ebay, thats the only thing I can find...
its for a polaris 2004.5 500 HO
Old Sep 6, 2004 | 07:07 PM
yaK's Avatar
yaK
do a search on here.....for light mods...lots of old topics will tell ya the easy way to do it for under a buck....or just push it carefully between the two settings ....it usally never moves off it for me !
Old Sep 6, 2004 | 07:41 PM
you don't need a kit.. its a do it your self thing.. we did it to my ol mans wheeler. very easy.
Old Sep 6, 2004 | 09:54 PM
20045SP500HO's Avatar
i wired this up in a couple of hours ... used a relay and mounted a switch on the side of the pod. Now i have low, high and both. up the r
Old Sep 6, 2004 | 09:59 PM
Tom128
The kits cost $10-$20 on ebay. I went to radio shack and purchased a four pak of diodes, heat shrink, and some wire for about $6. I have enough to do four quads. Im' sure you are bound to have some friends that would like to do this mod also.
Good Luck
Bloomer
Old Sep 6, 2004 | 11:14 PM
mdd2121's Avatar
The easiest way is to just put the switch in the middle of high and low. All lights work if you get it just right.
