shims
Old Sep 9, 2004 | 01:05 AM
o4ScramblerKing's Avatar
Default shims
when a belt gets old and loose do u need to pull out a shim? if u put in a new belt on do u put that shim back in. what happens when u run out of shims. just wondering because my has a lot of play in it . the same belt has been in for about 5 months .thanks
Old Sep 9, 2004 | 01:10 AM
BigBadScrambler's Avatar
Default shims
I have never had to do anything with the shims. But, you have to have at least 1 shim behind the clutch
Old Sep 9, 2004 | 01:40 AM
Lukester's Avatar
Default shims
o4ScramblerKing,
Outside of alot of play, what are some of your symptons?
Lukester
Old Sep 9, 2004 | 05:30 PM
Default shims
harder 2 get it on two wheels. will a new belt make it tighter? what happens when u run out of shims. i got all of mine still in there.
Old Aug 13, 2006 | 02:54 AM
Mudjive's Avatar
Default shims
What is a shim? what do they do and look like?
Old Aug 13, 2006 | 11:00 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default shims
shim is a big wahser but thin. belt only 5 months old shouldnt be bad unless you burnt it.
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
92LT
Sep 26, 2002 09:53 PM
Hightower
Jul 29, 2002 04:59 PM
ScoobyDFW
Mar 7, 2002 02:53 PM
ScoobyDFW
Jan 8, 2001 12:25 AM
