Starter Block off?
Old Oct 4, 2004 | 02:37 PM
ScramblerXLE's Avatar
Default Starter Block off?
Hey guys,
i was wonderring how much weight this saves... will i feel the difference? the Scrambler is easy enough to pull start so i don't think that'll be a problem... but is it worth the weight savings?
Old Oct 4, 2004 | 02:42 PM
scrambler123's Avatar
it takes off a lot of weight and is worth it.
Old Oct 5, 2004 | 08:07 PM
hot seat's site says it only removes 4 lbs... gas in the tank or not is way bigger a difference... or is HSP full of it? thanks
Old Oct 5, 2004 | 08:12 PM
thewayout420's Avatar
if you only remove the starter you will save about 5 lbs,if you remove the starter,battery and the battery box that will save you avout 13 lbs or so..
Old Oct 5, 2004 | 08:13 PM
Troyer23J's Avatar
That sounds about right, its not alot. But, by romoving it, you can race lighten the flywheel... That makes a big difference in how fas it will rev.
Old Oct 6, 2004 | 01:55 PM
i think i removed about 15 pounds when i took mine off including the starter, battery, box, and wiring.
ReconBayou
Oct 31, 2022 05:37 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
