blade lift
Old Oct 4, 2004 | 06:05 PM
polarisman3's Avatar
Default blade lift
well i got tired of always having corrosion problems with my rotary switch on my warn winch, i could have bought a rocker switch but i wanted somthing different. I dont like hand lifts either so I decided to lift it with pneumatics. ... I used a stainless steel cylinder a two position 3 way toggle valve which is nice cus you can just flip the switch to lift it....and it also floats when the blade is down... I had to make a mounting bracket for the cyl to mount to; i bolted the bracket to the front rack...I use an air tank precharged to 100 psi so you dont need an air compressor onboard...i also use a regulator set at about 60 psi to conserve air, it only uses about 2 psi per lift...i would have pics but i tore it down untill reassembly this late fall....
Old Oct 4, 2004 | 11:13 PM
Polaris500HO4x4's Avatar
Default blade lift
through up some pics
QuadRiders
Oct 22, 2015 04:13 PM
readymixer169
Aug 21, 2015 10:05 AM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
mr.bear
Aug 5, 2015 07:51 AM
