Can I get rid of single lever braking?
I think it would be fairl easy i plan on doing it myself. I think all we have to do is block off the line that goes from the T-intersection back to the rear cylinder and then put a screw in where the line runs to the rear brake caliper.
Hot Seat has a kit which includes all the hardware to do this. Includes a new master cylinder, brake lever, and line to allow use of rear brake with the right hand. Part number ATVSBK & cost is $139.
You could just plug the line from the junction block but then you would only be able to brake with your foot to the rear. Hope this helps.
Farmr
Farmr
oliveiracarlos
Sep 7, 2015 03:39 AM
