2003 polaris 600 sportsman will not idlw
Old Oct 14, 2004 | 02:00 PM
dacoach's Avatar
Default 2003 polaris 600 sportsman will not idlw
My 2003 600 sportsman will not idle. What may be the problem
Old Oct 14, 2004 | 05:12 PM
97RamSST's Avatar
Will it just not idle at startup or like if you started it up then ride it for a while it still won't idle?
Old Oct 14, 2004 | 05:31 PM
polarisman3's Avatar
well if it dies right when you let off the throttle then you more than likely need to tighten your throttle cable. the adjustment is on the handle bars...pull back the rubber slip and tighten it just enough so it idles at the recommended rpm...just a thought...look in your owners manual for the procedure....
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Coryco
Jul 6, 2015 07:30 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
