water dirt in front hub???
Old Oct 14, 2004 | 08:12 PM
lancesamuel's Avatar
Default water dirt in front hub???
Just seeing what could be wrong or how water got in front hub.. I replace front a arm few weeks ago I hit stump bent a arm.. Could I have done something insde the strut where a arm attaches to ball joint.
I did notice my plastic front hup cover leaking a little could water and dirt gotton in through there.. Any ideas or help would be very greatful. Thanks It is a sportsman 500ho 2001
Old Oct 14, 2004 | 08:22 PM
BigBadScrambler's Avatar
You could have damaged the hub seal when removing it or reinstalling it. Does the hub leak fluid at all? Possibly some dirt stuck around the seal
Old Oct 14, 2004 | 08:49 PM
Bradracer18's Avatar
Yeah BBS is right, you probably didn't get them back in correctly or something was bent(like a seal or something).....I wouldn't think it could leak in water without leaking out fluid though, so look around.......
Old Oct 14, 2004 | 08:53 PM
Which seal you talking about the black round ruber one that is on the plastic hub cover
Old Oct 14, 2004 | 09:00 PM
I don't know too much about your quad.....but I would think it can only leak in two places.....on the inside(towards the radiator) and the outside(towards the wheel)....but maybe I'm wrong.
Old Oct 14, 2004 | 11:37 PM
Im talking about the big black rubber one on the back side. That is most likely where it would be leaking from. The seal on the hub cover is just an o-ring and cant be replaced cheaply and easily. Teh big main seal is a little more involved. Fill it up and check for hub fluid on the back sid of the rim
Old Oct 15, 2004 | 12:32 AM
Snowwolfe's Avatar
What year is your quad? I am not sure what year they changed the front hubs from the style the 6x6 still uses. If its the "old" style and the hub is leaking all you need to do is to remove the hub and have a new seal installed. Its an easy fix and has to be done every 2-3 years. $20 tops for the seal.
Frisky2050
Apr 9, 2020 11:19 AM
Nondem
Feb 22, 2020 12:20 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
