blowin' smoke
Old Oct 15, 2004 | 04:03 PM
Ridinghard's Avatar
Default blowin' smoke
I tried this in another area, and got no responce, so I am trying here (where I've had lots of luck before)
I have a little 100 that burns oil and smokes. I'm thinking if I buy new rings it should be fixed. Any ideas? It has a lot of power so I don't think it more, but I want some opinions. I don't know if I'd know by looking at everything whether they were good or not when I get it apart.
Old Oct 15, 2004 | 04:14 PM
davesp's Avatar
Well with the 4 stroke 100 it may not just be your rings. It could also be your valve stem seals. You would have to pull the head to have that checked. Good luck.
--Dave
Old Oct 15, 2004 | 06:43 PM
BigBadScrambler's Avatar
Do a compression test first. If the compression is low, even though it still runs good, it is probably your rings. If the compression is good, then I would look more into the valve seals like Davesp mentioned
Old Oct 15, 2004 | 08:33 PM
Ridinghard's Avatar
Thanks for the help!
gets me on the right path.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
