scram 500 stalling in reverse
Old Oct 16, 2004 | 01:10 AM
ROLLaris's Avatar
Default scram 500 stalling in reverse
I have a '00 scram 500 4x4, and occasionally when moving the gear selector into reverse while the engine is cold, the engine stalls out. If I hold in the reverse override while shifting to reverse, it'll stay running. Once the quad is warmed up it's fine. Any one else have this problem?
Old Oct 16, 2004 | 01:29 AM
Sidewinder500's Avatar
I have to use my reverse over-ride button regardless of whether it has warmed up or not.
Old Oct 16, 2004 | 07:49 AM
ftwflh's Avatar
Your reverse override is bad.If you wont be bothered with it not working pull the front nose piece off ,find the reverse limiter and unplug the BLACK wire.You will still need to hold the button in to have 4x4 in reverse but it will disable the rest of it.
Pehter
Oct 3, 2024 11:00 PM
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
