Tires? ( filling with air question)
Old Oct 31, 2004 | 01:50 AM
ToSlow's Avatar
Default Tires? ( filling with air question)
I've got one of those kits with the co2 cartriges I think it was two cartriges to fill a tire I usually keep around ten in a pak just incase you get more than one flat also I'm always riding with somebody that doesn't believe you can get a flat
Old Oct 31, 2004 | 02:54 PM
BigBadScrambler's Avatar
Going from a flat tire. It takes about 2 CO2 cartradgs to fill the tire up. You can get enough air to ride it with 1, but I like a little more pressure in mine
Old Oct 31, 2004 | 05:56 PM
MaineMudder3's Avatar
I agree..I have one of the devices I bought a while ago that uses 12 gram co2's. Takes 2 from a dead from bein dead flat to get it to good riding pressure.
Old Oct 31, 2004 | 10:12 PM
tyler711's Avatar
Are the 12 grams threaded, or do they just puncture the foil on the top? Because the kind we use for paintball are not threaded, and you can buy them in bulk for pretty cheap. If they are the same, they are probably cheaper than the tire kit ones.
Couldnt you use a couple adapters to make your own thing that would go from the 12 grams to the tire valve?
Old Nov 1, 2004 | 01:12 AM
  #15
The CO2 inflater that I have from Genuine Inovations (JCWhitney) can use threaded and non-threaded 12g or 16g cardtradges
Old Nov 1, 2004 | 04:47 AM
  #16
jsyi's Avatar
Not to sound like a dumbass but whats the diff between 12 and 16 gram?
Old Nov 1, 2004 | 03:20 PM
  #17
The 16g is a bigger cardtradge. The 12g are what most CO2 pellet guns use. You can get them in bulk for fairly cheap.
Old Nov 1, 2004 | 05:56 PM
  #18
tyler711's Avatar
12 grams are on paintballgear.com for .69 each or discounts for bulk. I am sure they can be found cheaper elsewhere, but i have dealt with this reliable site many times before. Note these are unthreaded 12g cartridges: clicky
toonces
Oct 16, 2019 12:11 PM
Ean
Aug 28, 2015 09:39 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 10, 2015 04:54 PM
