Polaris Hub Fluid
Old Nov 22, 2004 | 07:50 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default Polaris Hub Fluid
4 o'clock sounds right
Old Nov 22, 2004 | 09:51 AM
canuckPT's Avatar
Sooooo - I guess I should just turn them to the 4 (or 8) o'clock position and let the excess drain out and when it stops I should be all set. Does that sound right?
Old Nov 22, 2004 | 10:46 AM
Seppi's Avatar
Yes Sir,
Goona do mine this morning!!!
Seppi
Old Nov 22, 2004 | 12:36 PM
GST97's Avatar
I know on mine, I am supposed to fill it at the 3 oclock position. I generally fill it straight up, then spin it to 3 and wait for it to stop leaking out. kind of like how a manual transmission on a car is filled [img]i/expressions/face-icon-small-wink.gif[/img]
By holding it at 4 oclock, you wouldn't have much fluid in there at all, at 3, its approx half full of fluid and should plenty of room for expansion.
-Chris
Old Nov 22, 2004 | 02:11 PM
  #15
Seppi's Avatar
Got the seal on the hub changed,refilled the hub to the 4 o'clock position . took it for a ride and wouldn't you no it ,no more leaking from the seal area ,which was my original problem! Also fixed the spongee brake problem,I had to use the vacuum bleed method... Even the so called (emergencyBrake) or foot pedal locks the rear brakes if needed!!!
Thanks again for the help people !!!!
Seppi
Old Nov 22, 2004 | 05:46 PM
  #16
Snowwolfe's Avatar
If i was going to add fluid I would add it and reinsert the screw then spin the wheel a few times and drain the fluid. Repeat a couple of times. The hub requires so little fluid its good insurance to flush a few times.
Old Nov 22, 2004 | 11:01 PM
  #17
I4WHEEL's Avatar
The best way to change yor fluid is to unscrew the hex bolt then drain all the old oil out. Then fill the hub up in the 12:00 position and move your wheel back and foward a few times but be sure not to go past the 2:00 position. After you have done this turn the hub to the 3:00 position and if oil starts to come out of the hub you have enough oil in it. You may have to repeat this a few times to make sure you have the right amount of oil in it. Your hubs will hold 4 oz. of oil for each side. Not enough oil will result in your hubs not wanting to engage and disengage properly.
Old Nov 23, 2004 | 12:02 PM
  #18
Bing's Avatar
Super Quad Patrol
did my hubs yesterday
that old fluid was dirty[img]i/expressions/face-icon-small-disgusted.gif[/img]
Cole Hadden
Jun 15, 2025 09:05 AM
NatePerz
Jul 27, 2015 03:27 AM
Sandman2.0
Jul 21, 2015 09:03 AM
maxjung
Jul 13, 2015 05:11 PM
rcappie4
Jul 10, 2015 04:54 PM
