clutch spring questions
Old Oct 23, 2006 | 07:59 AM
ftwflh's Avatar
Default clutch spring questions
That is close to what backshift is.And thew 500 has enough power to pull in any rpm range
so if you want it to engage low it will pull at the low rpms.
You can run the white spring with a stock 1-1 secondary setting it will just not backshift as quick
and have a little dif top rpm
Old Oct 23, 2006 | 10:51 PM
sportsman40005's Avatar
On my 400 the sec. clutch is set up on the 2-2 setting . Is this ok ? or , should I set it up on 1-1 ? what if I stay with stock primary (blue I think ) spring 1-1 or 2-2 ?
thanks
ghost civic
Jan 15, 2020 07:43 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
