Trailblazer 250 - Snow Blade
Old Dec 2, 2004 | 07:06 PM
rrkramer's Avatar
Default Trailblazer 250 - Snow Blade
I have a Polaris Trailblazer I would like to order a Snow Blade for the front. I would like to use it for light plowing instead of a shovel. Anyone have any idea's or suggestions on where I can get one, or will I have to weld one on my self.
Thanks,
Ron Kramer
Polaris 250 - 04'
Old Dec 2, 2004 | 07:20 PM
Freddy22's Avatar
Try , www.Highlifter.com
Old Dec 2, 2004 | 07:32 PM
DGpolaris2346's Avatar
I got mine from cycle country. Its easy to install and takes about a minute to put it on and another minute to take it off. PM me and ill get you some pics if you would like.
Old Dec 2, 2004 | 10:56 PM
BryceGTX's Avatar
Hello rrkramer. I also have two Trailblazers. I picked up a Honda blade at an auction for a little over a hundred (can't remember exactly). I just finished making a mount for mine. It bolts on top of the frame between the two front lower A-arms. It is made with a 10 inch 3/8 inch plate that I welded a 2x2 cross piece that holds 3/8 inch thick vertical flat iron that extends down though the A of the a-arm with quick disconnects for the plow. I made the mount this way so that only a small portion of the vertical supports extend below the bottom of the quad. I bought chains for the rear wheels at Tractor Supply for $50 and a few dollars extra for the chain spring tightener thingees. I have still yet to figure how I am going to lift it. I haven't decided if I would make a manual lift or buy a winch. I have been looking at the wheel weights at either lowes or Home Depot (can't remember which). As soon as I get it finished, I will try to post some pics.
I hope this helps you. [img]i/expressions/face-icon-small-smile.gif[/img]
BryceGTX
Irishman301
Sep 23, 2015 01:47 PM
stcspiderman
Sep 13, 2015 05:15 PM
awer1968
Sep 8, 2015 11:02 AM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
