Question about FMF Slipon (predator)
Old Dec 5, 2004 | 08:39 PM
shawn7's Avatar
Default Question about FMF Slipon
I just got my new slip on and was trying to install, but ran into a snag.
Where the head pipe and stock exhaust meet, there was a type of seal that fit around both the exhaust and header pipes (found this once I removed the header clamp). The new slip on would not fit over the existing head pipe with it on. So, I removed it (had to cut off w/box cutter). The new slip on fits nicely over the head pipe. But when I put the OEM Header clamp back on, it will not tighten enough to make a difference. So, should I go buy some type of grommet (sp) to replace the one I took off, or should I go buy some clamps and assume the silicone and clamps will keep it from leaking?
Thanks and sorry for the confusing description.
~Shawn
Old Dec 5, 2004 | 11:00 PM
sand45's Avatar
Default Question about FMF Slipon (predator)
Shawn.....I think you should be good to go with new clamps and silicone.
Old Dec 5, 2004 | 11:12 PM
modquad's Avatar
I would contact FMF's product support crew and find out what they suggest. Were there directions included with the product?
Old Dec 5, 2004 | 11:59 PM
mudmaster250's Avatar
hey, where have u been modquad. the forums needs u!! we want to here all u know about the pred and such. please come back and enlighten us!!
Old Dec 6, 2004 | 12:04 AM
shawn7's Avatar
Yeah...I'm not sure if I was reading it wrong or what...
"1] Loosen the OEM header clamp at the front of the muffler.
2] Slightly loosen the header flanges at the front of the motor.
3] Loosen and remove the front OEM muffler bolt.
4] While holding the muffler, loosen and remove the rear OEM muffler bolt. Keep for later use.
5] Gently slide the muffler rearward to release it from the header. Spray WD-40 on the joint if it is
difficult to remove.
Slip the muffler inlet over the header.
10] Slide the long strap bracket carefully over the muffler and position it to the front upper mounting
point. Be careful not to scratch the aluminum canister and make sure the “inside” sticker on the
bracket is towards the subframe."
No where does it say to remove the existing piece or what....
~Shawn
Old Dec 6, 2004 | 12:50 AM
RAJ's Avatar
RAJ
How big is the gap? If it real big call FMF and tell them, if it real small use the high temp silicone.
Old Dec 6, 2004 | 09:37 AM
Flynbryan's Avatar
They probably should have supplied you with a new clamp. When I bought my HMF they gave me a new clamp for the union. As others have said, call FMF and let them know your problem. They may have just forgot to include the clamp.
Old Dec 6, 2004 | 10:49 PM
Bradracer18's Avatar
Are you talking about that little bit of packing that gets left on your header pipe due to heat?? Mine did that a while back, but I got my pipe to fit back over it......
Old Dec 6, 2004 | 11:41 PM
shawn7's Avatar
Not any build up. It (I think) was like high temp tape. I just siliconed it and bought new clamps.
Now, I seem to be hitting the rev-limiter a lot quicker. Someone recommended a new CDI box?
Does that sound right?
~Shawn
Old Dec 6, 2004 | 11:47 PM
The nicholas cycle (expensive one) is really good......I think it is vortex. But it is pricey.........they also have some that aren't near as expensive too.
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
greg86hd
Sep 16, 2015 12:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
