Polaris 500 wont start! Need help!
Old Dec 7, 2004 | 10:23 AM
horn's Avatar
Default Polaris 500 wont start! Need help!
I have a 99 Sportsman 500, for some reason it won’t start. The engine turns over and it acts like it wants to start, but then it doesn’t. After trying to choke it, I then start to smell gas (flooded). I have no idea what it going on with it. Gas is about a month old.
I did find a broken ground wire from the engine to the frame, but after fixing that still nothing.
After trying and trying, I’m thinking about taking it to a dealer, but I know the cost will be out of this world. Any help would be appreciated.
Old Dec 7, 2004 | 10:57 AM
pooboy2's Avatar
may try a new plug and air filter mine was doing kinda the same thing and I didn't think it looked or was bad but when I changed both it seemed to fix it. might just save a big shop bill!![img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 8, 2004 | 12:56 AM
BigBadScrambler's Avatar
If you are getting gas through the carb and have a good spark and compression, then I would take a look at the valve clearences. If they have not been adjusted in a while, they could have gotten too tight and wont let the valves open all the way. My dealer tech was telling me about an 04 SP500 that he had that did that because the owner had put over 1000 miles on it in the first 6 months and hadn't had his valves adjusted
Old Dec 8, 2004 | 01:15 AM
rangerchet's Avatar
Two things, 1. take off your air-filter cover and make sure your filter is clean.
2. In the above no.1 condition with the cover off. turn the motor
over and spray a little starter fluid on the air-filter and see if it will start. Its not a permenant fix but
if you would just like to get it started for now. Try that. It usually will reek gas after you have chocked it for a time and turned it over and over. Thats normal when it don't want to start. - rangerchet
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
1000gade
May 27, 2015 12:37 PM
