Right front hub wont engage
Old Dec 31, 2004 | 04:01 PM
TATERDAD's Avatar
Default Right front hub wont engage
TRY OHMING OUT THE 4WD HUB COIL WITH A OHM METER TO SEE IF YOU HAVE A OPEN LOOP. THEN WITH THE KEY ON ON FWD GEAR AND AWD ON SEE IF YOU ARE GETTING 12 VOLT ON THE TWO WIRES COMEING TO THE COIL. IF 12 VOLTS PROBLEM IN COIL OR OTHER HUB SUFF. LET ME KNOW AND I WILL TRY TO HELP
Old Jan 1, 2005 | 01:42 PM
polarbare21's Avatar
thanks...
I hope to ohm things out today.
Old Jan 1, 2005 | 01:46 PM
Polaris500HO4x4's Avatar
check your armature plate... if im not mistaken the slightest bend or warp will cause the hub to work improperly
Old Jan 1, 2005 | 08:12 PM
jeepsterfl's Avatar
I had the same problem with my 96 sportsman 500, make sure the dowels expand and contract nicely, if not buy the aluminium housing. I filed mine down so I could push through the dowels with a little effort. It's been working fine for a long time.
Good Luck
Old Jan 1, 2005 | 09:23 PM
  #15
Got it Fixed!!!
Thanks to all!
The electronics were fine, mechanically the rollers and hub surface where they ride were a mess.
I cleaned the rollers up with a wire wheel on a griner, and used a dremel tool to clean up the inside of the hub.
Lots of contact cleaner on the bearings and other surfaces. Reassemble, add Mobil 1 ATF and it drives now!!
Many thanks guys!
Polar
carolinabomb
Jul 26, 2015 08:40 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ghost civic
Jul 15, 2015 10:48 PM
tporath
Jul 11, 2015 12:31 PM
coolguy420
Jul 10, 2015 01:17 AM
