Tire pressure?
Old Jan 1, 2005 | 02:49 AM
tiresage's Avatar
Default Tire pressure?
What was the ride height change with the progressive springs ??? Did you get the kit with the preload adjustment??? I saw an atv site that sells "firm" springs for rear of SP700 - about 30 lb/in more tension. Mabey that would be the way to go, although I don't want to get beat to death when riding for hunts. How much change in recoil did you get when swapping to the progressive kit. Does it jar your teeth out???
Old Jan 1, 2005 | 02:51 AM
elkbow's Avatar
I bought the kit because Progressive had a 'Press Release' saying they had new progressive springs for the '05....but they don't....the Black springs were their springs, made for the 2004 and earlier models....the Red springs were the stock springs from my 2005....as you can see you can't put the Progressive springs on the 2005 as the 2005 has much more travel and the stock springs are progressive rated springs....
Old Jan 1, 2005 | 02:55 AM
tiresage's Avatar
I see.......... From the pic - It looked like the shorter spring might have had a higher compression rating - I assume you sent them back. Mabey someone with the older susp. like mine can share some insight. Very impressive picture gallery by the way. Thanks for your help.
Old Jan 1, 2005 | 03:04 AM
elkbow's Avatar
I sold them to one of our forum members.....I heard they are definitely an improvement on the front end of the '04 and before machines....they have an adjuster that goes under the springs, so you can change load easily with the turn of a wrench....from what i've heard, when the adjuster is in the softest setting, they are about the same as stock, but progressive....alittle better feeling....then you can change as you need from there, like if you are running a plow on the front end, would definitely help....or if you load the racks...or if you ride and turn hard....
when I told Progressive that their website was wrong, they said 'oops, our marketing guy screwed up, let me see what we can do for you'....last I ever heard from them, and that was the manager of engineering that I talked to....
Old Jan 1, 2005 | 03:14 AM
  #15
Polaris500HO4x4's Avatar
Originally posted by: 20045SP500HO
I would run around 10psi, if the tire can take that much psi. IMO after 50 miles of road use you wouldn't have much tire left.
what do you mean 50 miles and not much tire left??? im around 1000 miles on ashpalt and i got half my treads left
Old Jan 1, 2005 | 03:45 AM
  #16
elkbow's Avatar
depends what tires you have on....if you have a stock knobby or something similar, they will last awhile on asphalt....if running a mud tire alot of pavement, they wear quickly....
where do you ride that you are putting that many miles on pavement....I wish in NM that ATVs could be made street legal....we have to register the damn things, so why not let them be street legal.....I could see pulling in to work on my 700 EFI...lol
Old Jan 1, 2005 | 04:10 AM
  #17
i run alot of roads around here... mostly unpopulated county roads , just got it from the warden last night... just a warning tho
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Hw00d
Sep 10, 2015 08:53 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
