Gear and transmission Fluids
Old Jan 4, 2005 | 01:19 AM
BART323's Avatar
Default Gear and transmission Fluids
I am going to change the front and rear gear case fluids and the transmission fluid, other then the Polaris synthetics what can I use. Walmart and the auto parts store are closer then the Polaris dealer. This is for the SP 400. Thanks for the help. BART
Old Jan 4, 2005 | 09:26 AM
JAMIEZ71's Avatar
In the sportsmans Tranny and Differentials it's recommended not to use anything other than Polaris Oils. I would suggest driving to the dealer and not worry about the extra mileage to the dealer. I'd rather do that than chance using another oil.
Old Jan 4, 2005 | 05:41 PM
BigBadScrambler's Avatar
If your SP400 has the hillard clutches in the front hubs instead of intergrated in the front gearcase (which I believe is the case), then the front gearcase would take any syn. 80W-90 gear oil. I believe that the same would be true for the rear gearcase as long as it is not intergrated into the transmission like the newer ones. In the transmission you can use Amsoil Series 2000 chaincase lube
greg74
Sep 10, 2019 03:03 PM
cornermike
Aug 10, 2016 06:47 AM
Polaris5
Aug 29, 2015 09:11 PM
oldschool64
Aug 12, 2015 07:13 AM
rcappie4
Jul 10, 2015 04:54 PM
