BACK UP LIGHTS
Old Jan 8, 2005 | 07:50 PM
HELLHOUND's Avatar
Default BACK UP LIGHTS
Is there a kit or mod to add back up lights to a 2004.5 sportsman 500
thanks
Old Jan 8, 2005 | 07:54 PM
elkbow's Avatar
not factory....but you can always get a set of 12v lights and mount them in various positions on the rear and put a switch in the pod....you just have to be careful, don't get big ole' driving lights, the burn way too much power....
i will also suggest that maybe you wire in to an 'ignition hot' wire so that you don't leave them on while riding...
dave
Old Jan 8, 2005 | 08:08 PM
2manytoys's Avatar
You do not really want to put a switch on it because I have seen more people leave them on and kill a battery or ride with them on. It is very easy to hook the light up to the tranny. Just get a 12v light for the rear and mount it. Take the hot wire from the light and hook it to the battery. Then take the ground wire and hook it to the brown wire from the harness that goes to the tranny. Thats it! When you put it in reverse the light will come on and when you go to neutral or forward it will go off.
Old Jan 8, 2005 | 08:15 PM
elkbow's Avatar
thats why i said connect it to the ignition hot wire, that way you won't forget it is on.....Reverse is not the only time you want to use this light...on the 2005 Polaris machines like I have, its called the 'work light'....you can use it when you need it....I used it part of the time this year while I was quartering out my elk in the dark....worked great....
if you put on a lighted switch, thats best, I plan on replacing my '05 work light switch with a lighted switch..
Old Jan 8, 2005 | 08:47 PM
2manytoys's Avatar
I guess you could hook it up either way. If I need a work light then I just keep it in reverse. That way I know for sure I will never leave the light on. Just thinking ahead thats all. I did not mean to shoot your idea down either. Sorry!
Old Jan 8, 2005 | 11:07 PM
Sean99TJ's Avatar
Your local napa auto parts type store will have good lights for this..they are about 10-12 bucks each, rubber cased all weather. I have 5 of them under my jeep so the spotter can see the rocks at night. I also am not a fan of passing amperage of lights through a switch to power lights. I would recommend using a relay. I would set this up a little different than the other 2 ideas (even though they will definately work)... I will use both. I would use a relay that has two (2) input control signals. wire straight from the battery thru the relay to the lights to ground. I would wire the one control side of the relay to the tranny(brown wire I believe was mentioned), and the other control side to a switch so that I could have them on if I wanted them on.
Old Jan 8, 2005 | 11:38 PM
elkbow's Avatar
No apology necessary, your idea was good for backup lights and I'm sure thats all some need. The work light on the Polaris '05 machines is nice, but not really bright...works better as a backup light. I need to come up with something that can give alittle more shine, not sure how often I would use it. When I quartered out my elk this year, i didn't want to leave the machine running the whole time since I was sucking in exhaust, so I had a small streamlight scorpian in my mouth part of the time. Like a dumb ***, I forgot I had a headlight, that has a band that goes around the head.....its pretty bright....but forgot it was in there....duh.
oh well....if you have any idea's or anyone finds any good lights that don't suck all the power out of the battery, let me know....
dave
Old Jan 9, 2005 | 11:55 AM
HELLHOUND's Avatar
Thanks for the info
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
MrElussive
Dec 12, 2000 05:13 PM
trx430ex
Nov 15, 2000 01:26 AM
