2001 Sp 500 HO Snorek seal replacement
Can someone tell me if the seal can be replaced on the snorkel that leads to the front prop shaft without having to remove the transmission shaft. Mine is leaking and needs to be replaced. If the shaft can be left in any tips on getting the old seal out. This would be the triple seal, part number 5 on the gear and snorkel case microfish.
