Elkbow's Next Project
Old Feb 14, 2005 | 04:42 PM
  #21
BigBadScrambler's Avatar
Default Elkbow's Next Project
Originally posted by: 20045SP500HO
I don't understand where he put the the oil temp probe? And it looks like an mech guage for oil ... that seams alittle harder to do than electric?
The oil temp probe wen in the front of the cylinder head, onthe left side of the header. There is a small 1/8" recessed plug in the head that you remove to check oil pressure. That is where it goes. It too is a mech. gauge. Oil travels through a tube to the gauge and reads the pressure.
Old Feb 14, 2005 | 05:07 PM
  #22
20045SP500HO's Avatar
How much pressure does it produce?
also
It's a service plug that you put the sensor into?
Old Feb 14, 2005 | 05:19 PM
  #23
It is a service plug where you insert the probe at. At idle, there is less that about 3psi. Around 3K+ RPM, it is around 20psi
Old Feb 14, 2005 | 05:29 PM
  #24
thanks!
Old Feb 15, 2005 | 09:56 AM
  #25
jefffoxsr's Avatar
Guys,
When I remove the probe for the temp gauge is coolant going to pour out? If so, what did you do to prevent it?
Old Feb 15, 2005 | 10:12 AM
  #26
Yep coolant everywhere [img]i/expressions/face-icon-small-smile.gif[/img] I just bough more Polaris premixed antifrezze and added it after.
Old Feb 15, 2005 | 12:03 PM
  #27
jefffoxsr's Avatar
Thanks
Old Feb 15, 2005 | 12:09 PM
  #28
My dealer (i really trust this guy, he very helpful ... not just out to sell u something) ... said the polaris stuff had something (?like lube? can't remember what he called it) for the cooling system ... he really said it was better (the polaris premix). But if i wanted to use something else to make sure i flushed out all the old stuff before changing.
Old Feb 15, 2005 | 12:34 PM
  #29
jimmypsp700's Avatar
jeff,
Put a cork or tapered rubber plug in the hole to prevent excess spillage.
Old Feb 15, 2005 | 12:38 PM
  #30
MAN ... looking at my last post ... i need more coffee!
