Running a 400 on Premix - Disabling the oil pump
Old Jan 9, 2006 | 01:17 AM
BigALFX4's Avatar
Default Running a 400 on Premix - Disabling the oil pump
how much oil do you use in a 40:1 premix ratio
Old Jan 9, 2006 | 01:56 AM
handycap's Avatar
Pre-mix, now you will be smoking all the time, using a lot more oil than ever before, need to rejet so you don't lean out. More oil means a leaner burn all the time.
On my 400 Trailblazer I use 1-2 gallons of oil a year. On the BUBBA BIKE I pre-mix and use 16 ounces every fill up and that equals 2 gallons a year and ride it 10% of the time, and smoke a lot more burning oil all time at same ratio instead of injecting it with throttle placement.
On my '94 400L put 5600 miles without a oil injection problem, changed oil filter every year to 2 years.
One more thing, gas breaks down quicker pre-mixed than by itself.
Old Jan 9, 2006 | 11:47 AM
scramblered's Avatar
i must say polaris oil injection is no failure and very safe,i would suggest pre-mix on heavy engines mod only,as stated earlier,the injection is from
keeping the motor as clean possible with less oil used,the premix help
to save weight and keep the engine more lubricate cauze of the higher running temp and also help as a after run oil deposit to prevent ring scuffing then.
green giant
Jul 13, 2017 12:07 PM
3quadbob
Sep 18, 2016 09:46 PM
alex_2011
Jun 9, 2015 10:12 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
