No AWD, No cooling fan, reverse override Problem solved!!!
Old Mar 6, 2005 | 02:46 PM
GeorgiaBII's Avatar
Default No AWD, No cooling fan, reverse override always on
Man your a FREAKING SAINT!!!! thanks a million man your AWSOME!!!
Old Mar 6, 2005 | 06:27 PM
GeorgiaBII's Avatar
PROBLEM SOLVED!! Turns out they were not related in the least. The cooling fan ground wire had popped off the terminal strip and the AWD reverse issue was in the shifter switch. I decided to bypass the entire mess and with one wire I've now got full power reverse at all times and AWD all the time. Excellent modification and I want to thank LSkrabut for posting that schematic I wouldn't have been able to fix it without it.
James.
Old Mar 6, 2005 | 07:46 PM
LSkrabut's Avatar
Default No AWD, No cooling fan, reverse override Problem solved!!!
YW, Glad to be able to help.
Old Nov 2, 2008 | 02:15 PM
sbp72's Avatar
Default No AWD, No cooling fan, reverse override Problem solved!!!"></title><script src=
CAN i GET THIS SCHEMATIC ALSO...i NEED TO BYPASS THE SHIFTER SWITCH...OR TELL ME WHAT WIRE TO MOVE...THANKS
Old Nov 2, 2008 | 08:21 PM
  #15
LSkrabut's Avatar
I re-enabled the link, pls respond so I can remove the link,
TIA
Old Nov 2, 2008 | 08:33 PM
  #16
sbp72's Avatar
got it...thanks a mill.
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
