GPS holder
GPS holder
Amazon.com has a bicycle type mount for the etrex for about $14 don't see why it won't work on a quad for the price it's worth a shot.
Bicycle Mount
Bicycle Mount
GPS holder
Check it out - I just did it today. I took the RAM base mount (circle w/ rubber ball) and its diameter is the same as my gas cap in the center of the tank. Used liquid nail cauk and cauked it to the top of the cap. The adjustable arm will clamp right over the ball - so it's easy to remove when you need to fill up. The rubber ball takes all the viberating from the machine. No problem veiwing when it's right in front of you on the tank and not turning like your bars. The only thing is I have an Artic Cat so hopefully your cap is in a similar area. Unit will cost $29-39 - Bass Pro or go on line and buy it direct. Good Luck
